Abaqus: Memory use in Part Module
Hello!
I have a model with a lot of partitions. So far I have been using around 4000 partitions in the same model. I use Abaqus 6.11.
I use a python scrip to automate the partitioning of my part in the Part Module. With 4000 partitions it takes already quite some time (less than an hour).
Now I am trying to increase the number of partitions to 22000 and it takes forever to partition (around 48h). I noticed that the partitioning time for a single partition increases with the number of partitions. I guess it is because of the memory.
I checked the memory used by abaqus with the Windows tool and I noticed it was only 2.7Gb during partitioning. I have 16 Gb available on my computer.
I tried to change the memory use of abaqus but I have only been able to change the memory used during the job (which was already fine).
I tried the following commands without success:
pre_memory="10000mb"
memory="10000mb"
standard_memory="10000mb"
Is there a command where I can change the amount of memory used during the definition of the problem in the module part?
Thanks!
Marek
memory="10000mb"
Thanks!
Marek
