Small pressure driven generator
A few years ago I remember seeing a small device that produces power from gas pressure. It wasn't any large, but it pulled gsa from I want to say 1/4" line and then after the drop, you would send it back into the gas stream of higher pressure. Anyone seen this before?
RE: Small pressure driven generator
(2B)+(2B)' ?
Like I said, this was a few years back when I read this and I thought I still has the paper but just wanted to see if anyone else heard of it.
Bill
"Why not the best?"
Jimmy Carter
Walt
Thank you!
old field guy
That, if anything, would be the perfect overunity Dream.
Gunnar Englund
www.gke.org
I haven't seen much of it or any installed or even if this was a wild concept that was brought up but not working but anyhow there it is.
The TEC - 8 consumes a small amount of fuel
(3.0 CFH for N.G. and 1.0 CFH for Propane Gas )
in a flameless oxidizing catalyst to heat the hot side of
an array of Peltier thermoelectric modules.
Bill
"Why not the best?"
Jimmy Carter
"No, not a typo. It took a fraction of a gas stream, moved a turbine (pressure drop) and combined it back to another gas stream of higher pressure"
Yes, definitely a typo, epete was right. Shall read "back to another gas stream of lower pressure" The diagram shows that it simply utilizes the pressure drop across the local pressure regulator to extract some energy that can be used to charge a battery.
Gunnar Englund
www.gke.org
Bill
"Why not the best?"
Jimmy Carter
