Density of Steam with dependence on temperature and pressure
Hi there,
i need to specify the density of water at 4°C and 3 barg pressure. Due to calculation programm, i just can check the density either depending on temperature or pressure, not both. Same with tables. It seems to me, the values may are not correct, maybe the dependency between °C and p was not respected..?!
it might is a simple explanation for that, but im confused. thx for your help..!
RE: Density of Steam with dependence on temperature and pressure
