Need to add Thread callout to model and drafting
Hi All,
I want to add a note in the form of callout for threads in NX 8.5 model and import them to drafting.
In Pro/E it is possible to create notes in model.
Please provide me any solution whether I can add notes with leader in NX model.
Thanks in advance.
Sandeep
RE: Need to add Thread callout to model and drafting
Take a look at PMI.
kukelyk
You can add dimensions, notes and symbols by using PMI. You can also display sketch dimensions as PMI's.
Later, you can 'call' those PMI dimensions on a drawing.
And if it is only a thread you are after, you can retrieve Thread definition on a drawing by using Feature Parameters command.
