ABAQUS: FEM of pipes. Too many attempts made in this increment
Hello Good Day!
I am trying to model a pipe subjected only to vertical pressure. I have applied "roller" boundary conditions on each end of the pipes and spring elements(spring1) on the bottom half of the pipe. I always get the error Too many attempts made for this increment or time increment required is less than the minimum specified.
Max number of increment: 100
Initial; 0.001
Minimum: 1E-005
Maximum: 1
Initial; 0.001
Minimum: 1E-005
Maximum: 1
