Extrude input needs to be changed based upon expression value out of multiple sketches available.
Is there any chances where based upon a value of an expression extrusion input sketch needs to be changed.
i.e for ex if I have 5 sketches, an expression "Sketch No = 1"
-> When the expression Sketch_No value is 1 then Sketch_000 should be selected for extrusion
-> likewise if the Sketch_No value is 2 then Sketch_001 should be selected.
Thanks and Regards,
Maddy
Thanks and Regards,
Maddy
Maddy
RE: Extrude input needs to be changed based upon expression value out of multiple sketches available.
I didn't create with replacing the sketch. I just created a couple of extrude bodies and suppress them with expression.
If there are some additional detailed features (blends, chamfers, holes, etc.) on those extrudes, then I would have to create all those featutes on each extrude.
But then again, if there is only one extrude and I am just replacing the sketch for this extrude (with Reattach command), then lots of subsequent features will fail anyway and I will have to fix them manually.
Hope that this 'suppress by expression' option will help somehow.
here is a little bit smarter solution:
I uses object groups and supression-values. See the attached PDF-Dokumentation from me.
Enjoy it. Best regards
Michael
