Axial/Shear of Cross Beam
I'm having some difficult understanding some basic concepts. When I solve and get the results from member forces of M1, the axial is around 11 kips in tension, and shear is around 0.5 k. If I want the total vertical shear y force due to M1, do I need to hand calc and resolve 11 kips into a y-component and add it to 0.5 k?
RE: Axial/Shear of Cross Beam
If you need these in global results then you would take the local x, y and z results and calculate the global values based on X, Y, and Z based on the angle of M1 to the global horizontal.
