'48-53 Ford Transmission jumps out of second gear
A little background first: We took my brother-in-law's 1941 Ford 2 door sedan for a test drive to diagnose a miss in the 1948 flathead that only occured when hot in summer -- worked fine in winter. We finally removed the electronic distributor and replaced with the 1941 mecahnical, dual point, distributor and also replaced the straight brass connectors inside the 90 degree rubber boots on the dostributor with shade tree fashioned 90 degree brass connectors to relieve pressure on the crab distributor cap making it not fit securely onto the distributor base. This seemed to solve the intermitant miss problem. Much more to the story but not pertinant to the subject line except that the off-subject story required more test driving. After numerous test drives the transmission decided to refuse to shift into second and third (high gear). It would shift into Low and reverse ok.
This is a 3-speed standard transmision 1948-1953 era housing (some of the gears are from a 1957 pick up - a bit irrelvant because the guts are mostly or all interchangeable or maybe my bro-in-law is wrong about that? ). Unlike the 1940 Ford, the 1941 transimission cannot be removed from the bottom. Therefore we had to use 2 cherry pickers -- one to lift the engine and move it fwd and one to reach thru the door and lift out the trannie -- we are both old geezers so could not wrestle the trannie by hand. Sincro-meshes were well worn which was probably the probem? He had a spare transmission only needed seals at the side cover (another off-subject story requiring special modification of modern standad seals). With the spare trannie in place, it pops out of second gear but all other gears work fine.
We now have the transmission shifted into second, seat moved back, floorboard up, shift linkages from steering column removed from shift levers on trannie side cover, tansmission side cover removed. The second-to-third gear slider is fully in the correct position. ANY ideas?
Design for RELIABILITY, manufacturability, and maintainability
RE: '48-53 Ford Transmission jumps out of second gear
Mike Halloran
Pembroke Pines, FL, USA
Mike Halloran
I am beginning to dislike the overused "lol" in texting when a cc will do, but I did a real LOL for[ or ... you need an older geezer.]
RossABQ: I will check that link and suggest he buy that book but he is almost as cheap as me. cc
MikeHalloran, ISTR = ?
Jay Maechtlen
http://www.laserpubs.com/techcomm
just had to chip in here, I was 15 years old when I bought my first Car 1938 Ford V8 I had got hold of a american hot rod book and I was going to build me a hot rod! The gbox problem has been well covered by some of the very knowledgeable men out there I just didn,t realise how old I am!! remember that box so well, small addition to what that great contributor Mike O,halaran had to say about that spring ... one of the tricks in those days a to take said spring, trace its arc onto a piece of paper and using a pair of pliers work around the spring gently and expand it about a sixteenth of an inch offering up to the trace as a guide line. The next trick was if the synchro cones were worn was to silver solder the faces and turn them back to size this would have to be guesstimated but half the way up gear cone would be about right. Just thought it might be of interest to us old timers can truly identify with when "the other day could lift an Alfa g.box into position alone, bolt up and think no more of it, old age is unkind but that is what memories are built on. All the best with your project.
Golfpin
I copied and pasted your posting to an email for my friend who has the 1941 Ford and then remembered that I could also copy and paste the link for the thread which I did. I am presently visitng his sister (along with my wife)in a nearby community. He plans to rebuild the transmission we removed and already has a manual maybe the one from the website given above which website is on his favorites.
Another old geezer Golfpin>
