Variant engineering detrimental for future career?
if i have a job offer in a shop where you only do variant work, would that be detrimental to my future career?
By variant work i mean the following (actually there are two offers):
- smaller heat exchangers design. no calcs, only design of mostly tube-fin HE. (http://elletradiator.com/wp-content/uploads/2012/0...) this can be and it is partly accomplished by a master sketch template assembly. they have said that you do ~30 small projects in a day (by modifying a template of course).
- large bearing and gear design. there is some statics here and calcs, use of KISSSOFT for gears calculation, but the cad can also be driven from a couple of templates i'd say.
will that kind of work prevent me to work in the automotive industry for example, when i get tired of doing it? or plastic injection tool design for example (an area that also interests me, but i have no job offers due to the bad economy). i am 30, BS ME, if it matters.
there is also a third option, similar to #1, but much more broad (pressure vessel etc. acc. to AD 2000 Merkblatter), but i've heard that the intrapersonal relations are really bad in that company.
RE: Variant engineering detrimental for future career?
Hi
Are you working at the moment?
If your not working at present then I would take the job you want the most, if your in employment already then keep looking if the offers you have had don't appeal.
no, i've been fired due to bad outlook for the company (verifiable from their yearly reports).
if possible, i will take the gear design job, if not that, the HE job, if possible.
i'm just afraid that x years in that company will alienate me from a mold tool designer position and by that from the car industry altogether (more or less, at least as a design eng).
the original plan was a couple of years as a mold designer in a auto supplier company, then something better like component designer etc.
Hi
Well its easier to get another job while your in a job if you see what I mean.
Also think how detrimental a lengthy spell of unemployment might be.
desertfox
thanks.
in the end i got here:
not the best, but not far from it.
i will also study at home on statics and dynamics again.
too bad i didn't get the mold job though.
