Hefty columns
Hefty columns
Hello everyone!
I just want to find out your opinion about hefty columns in high-rise buildings or heavy-loaded structures: which type of column section is more economic - box column or jumbo section + cover plates? Any other pros and cons for each type of section?
RE: Hefty columns
In the literature that I've read, cruciform sections formed from a Wide flange and two WT's seem to get mentioned a lot. An advantage with that system is that you've got an accessible flange to bolt clip angles to on all four sides for girder connections. It seems to me that a cruciform cross section would have a relatively lousy torsional buckling resistance but that doesn't seem to be holding anybody back.
I can't wait to hear everyone else's answers!
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
RE: Hefty columns
Since the boiler and its structural steel are usually purchased by competitive bidding, economy is a major factor.
www.SlideRuleEra.net
www.VacuumTubeEra.net
RE: Hefty columns
Michael.
"Science adjusts its views based on what's observed. Faith is the denial of observation so that belief can be preserved." ~ Tim Minchin
