Change position of object with mesh attached
Hi, i have a problem with global mesh. After solving the simulation i want to go back to *.prt, change localization of object(rotation) and solve the problem again. Problem is that in *.fem the mesh is recalculated and then i need to improve some connections, mesh, stich etc. How can i omit that? Just use some local mesh or attach a mesh to the object, not in general coordinate. Do you have some ideas??
I am using NX 9.1.
I am using NX 9.1.
