Rotate Part or Assembly w Middle Mouse Button Preference
When I press on MMB with the intention of rotating the part
or an assembly, it rotates up to a point and then won't rotate further.
I was always able to rotate things 360 degrees on all axis. Is there
preference that, perhaps, I need to reset to get things to rotate all over? Thanks
RE: Rotate Part or Assembly w Middle Mouse Button Preference
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum Policieswww.superATV.com
www.scottjbaugh.com
I figured out what the problem was. Somehow the preference "rotate about scene floor" got activated.
I unchecked that, and all is good.
But thank you for your suggestion.
