How to apply Moment at node in ANSYS
Since I'm new to Ansys, I would like to know to apply moment at nodes using commands for the following example.
For the following rod geometry, find the rotational displacement at the free end, elemental force and torsional stress produced in it. Torque, T =398Nmm.
Given:
R= 25mm
G= 7.956 e-2 N/mm2
I'm attaching the rod geometry along with this.
Thanks to all in advance.
Nidhish Mohan.
RE: How to apply Moment at node in ANSYS
if you can't apply a moment load, though i think you can (maybe check the user manual, you sure can model a couple
Quando Omni Flunkus Moritati
