Compress foundation bearing stress calculation
I noticed that the equation for foundation bearing stress calculation for the skirt base ring design is different from the referenced book by Jawad & Farr. Is this an error or there is some reason behind the change? Thank you,
RE: Compress foundation bearing stress calculation
The equation in compress is
fc = Cc / (((tc - ts) + n*ts)*(d / 2)*K2)
However, in the referred book is
fc = Cc / ((ts + n*tc)*(d / 2)*K2)
Thank you,
Arbor
