Section Modulus Calculation
Good Afternoon,
I have been browsing the forum for a number of months and now I have decided to create an account, to further my knowledge and pass on what I currently understand.
I have a question which may be simple to someone but currently driving me up the wall.
It is about calculating section modulus's (moments of intertia) for a circular hollow section with a sector removed. From reading roarks forumulas for stress and strain I don't seem to be able to find a solution to my question.
I understand it is not as simple as calculating the moment of inertia of a circular hollow section and then subtracting the sector section.
Does anyone have an idea of how to calculate the moment of inertia of a circular hollow section with a sector removed?
Thanks to replies in advance.
RE: Section Modulus Calculation
1 - 1st draw the figure you want (scale 1:1)
2 - transform the figure in a region
3 - then check the mass property and you will have : area,perimeter, center of gravity, inertia moduli with reference to the axxis of the center of gravity or to another one
I had got so involved in trying to calculate the section properties I completely forgot about using autoCAD to find the section properties.
Michael.
"Science adjusts its views based on what's observed. Faith is the denial of observation so that belief can be preserved." ~ Tim Minchin
