Shading of a Particular Component Present in a Drawing VIew
Is it Possible to shade a particular component in a view . The view consists of a large assembly arrangement and i just need to shade a hose present in that assy. Every parts should be viewed as wire-frame representation.
Is there any special option available to do this shading instead of manually selecting the boundary and hatching.
Any comments would be really appreciated.
Using Drafting UG-7.5
RE: Shading of a Particular Component Present in a Drawing VIew
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks for your comments.
In my case , superimposing will not work out .Because the one i need to show in hatches is a hose routing which goes inside complex assy. So when it goes in id should be hidden and when it is visible , it should be shown in Hatches.
I have tried partial shading , but that also not works out good.
Finally i decided to do manual hatching by selecting the boundary curves. But there also i got one issue. While selecting the boundary curves of hose, the tube bend curves are selected as circles, instead of half arc. So, hatching is not coming properly. Is there any way to do this boundary selection hatching work out?
Thanks in advance
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks for the idea..In my case , the color concept wont work, as the output drawing should be in black and white.. So i prefer to make hatches (3 types to differentiate 3 routings)
Hello JOhn,
As i said, i prefer hatching and shading will not be apt for black and white drawing. :(
I almost OK with manual hatching now. THe only difficulty is while selecting the boundary curves, the spline arcs are selected as 3D .:(( Please see attachment)
