composite progressive failure analysis in Patran / Nastran SOL 600
Dear all,
I am using SOL 600 implicit nonlinear solver to simulate the progressive failure analysis of a multilayered composite laminate. And I used Puck failure criteria while defining material properties with gradual failure option selected. I am simulating the progressive failure analysis of a rectangular plate with a central hole under gradual tensile loading. The simulation runs correctly, but I have problem with fetching the required results. Since I am new to Patran / Nastran, I do not know how I can get results of first ply failure load and ultimate failure load of the laminate. Also I am not getting the load deflection curve as expected and I am just getting a straight line. So I request someone to help me with this. I need to know what kind of output results format and simulation parameters I have to use to get the desired results. I searched in tutorials but the materials for SOL 600 run composite progressive failure is very limited and I did not get enough information.
Thank you in advance.
Kumar
RE: composite progressive failure analysis in Patran / Nastran SOL 600
You need to post-process the t16 file in Patran. In Patran, you can use XY-Plot in the Results tab to create load deflection curve.
Hello hezhj2000,
Thanks for your valuable reply. Yes, I found out that I need to process the t16 file and got the load deflection plot as well. Now I have got another doubt, How can I determine the exact first ply failure load and the ultimate failure load from the obtained results ?. Thanks.
Kumar
Check the damage plot in your structure to determine the first ply failure load. Check this video starting from 9 minutes: https://www.youtube.com/watch?v=XHJvlwVmMJs.
For ultimate failure load, if you have the load-deflection curve, why can't you find that from the curve?
Hello hezhj2000,
Thank you once again for the reply. I have a problem now in plotting the load displacement curve. I am not able to see "Constraint Forces, Translational" in the results eventhough I selected this in the output requests. I need to have this to plot the load deflection curve since I am using displacement controlled test case. Any idea how to get the "constraint forces, Translational" results in the SOL 600 run ?
Kumar
I don't use Sol 600. I usually just use Marc. So I don't know the answer. But you can probably try other types of forces, if they are available in the results.
Hello hezhj2000,
That's Ok. Thank you for your help.
Kumar
