Inserting a part with 3 views into part dwg & assembly dwg
Hello :)
An engineering drawing part with 3 views(top,front,end) are spaced apart differently in a Part drawing and in an Assembly drawing. The Only way I can think of is to have 3 files one for each view then insert them in the part drawing and assembly dwg file. However there are many files. A 10 part dwg will generate a 30 part view files.
I am using a script file to generate these drawings.
How to have 3 views for 1 part in a file and insert it with the appropriate spacing between them?
Thanks!!
RE: Inserting a part with 3 views into part dwg & assembly dwg
Have you tried creating a layout?
With a layout you can have any number of viewports (views) that you want on a single page.  You can size and space the viewports to whatever you like and you can scale each view to whatever you need.
Hope this helps,
-Andrew
thanks Andrew I'll try it out 1st
