Slab on Grade at Interior Columns
I am curious to here from others on how they usually detail this. I have seen it both ways but more often the top option rather than the bottom. It seems that the bottom row of details would be more work. We have a project where the geotech is (sorta) recommending the bottom row of details so that the slab does not bear on the footing or pier. I am wondering though if the top of footing is a -1'-0" how much does the granular subbase really compress, why not just pour on top of the footing?
Thanks.
Thanks.
RE: Slab on Grade at Interior Columns
Yes, isolate the slab from the top of footing.
The bottom plan detail results in offset joints that will crack in odd places.
For the other two details, I have used the constant slab thickness shown in the lower details. Why do you think the bottom details would be more work? I would think the opposite.
Where there is a large gap between the top of footing and underside of slab, there could be a concern about adequately compacting the region around the pier, so backfill would have to be done carefully. Granular backfill or low strength concrete (Fillcrete) might be an option.
BA
At interior columns - do you size the diamond so that it covers the base plate?
At exterior columns - do you keep the same size as the pier? If yes how do you detail the control joint?'
Thanks again!
EIT
www.HowToEngineer.com
the exterior ones i typically use the same size as interior.
Honestly they are standard details which go on every set of plans my firm make that involve steel columns. I check but really don't think much about.
