'Thickening' curves
'Thickening' curves
In Siemens NX 9.0 is there a way to make a curve thicker so that it has volume? I want to model the engraving I am going to machine into a part and the best way I can think of modeling the engraving is to create curves on the surface and then somehow add three dimensional volume to the curve so I can perform a Boolean subtract of that solid from the base solid. The surface curves need to be created on freeform surfaces as well as flat, cylindrical or tapered surfaces.
...Thanks in advance.
RE: 'Thickening' curves
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
www.nxjournaling.com
Thanks...I will follow through with John Baker's suggestion.
