"batch" mode for element creation ?
is there an automated way to make a bunch of elements ?
i've got a list of N1 and N2 that i've extracted out of the model and need to make a set of beams. could give them all the same PID. they'd represent rivets between elements modelled at mid-thickness
thoughts ?
thoughts ?
Quando Omni Flunkus Moritati
RE: "batch" mode for element creation ?
Something in the likes of - see below.
This supposes that:
1) you've pre-created your beam property. specify the id in the code. Or use a prop object and select/create a new one.
2) your list N1 - N2 is in a text file in column format, separated by space(s). if not adapt the code
3) how do you orient your beams? nodeID? vector? cf part 2 of code
Be sure to fill in where specified.
Hope this helps,
AP
Sub Main
Dim App As femap.model
Set App = feFemap()
Dim s As String, sAr As Variant
Dim nodes() As Long
Dim el As femap.Elem
Set el = App.feElem
'*** 1) READ FILE
s = GetFilePath("","",,"Select file",0)
If s = "" Then End
'NB: only dim2 is dynamically redim-able in VB
ReDim nodes(1,0)
Open s For Input As #1
While Not EOF(1)
Line Input #1, s
If s ="" Then GoTo SKIPLINE 'skip empty lines
s = Trim(s) 'leading/trailing spaces
While InStr(s," ")<>0 'multiple spaces
s = Replace(s," "," ")
Wend
sAr = Split(s)
'dyamic array which stores N1 - N2
If nodes(0,0)<>0 Then ReDim Preserve nodes(1,UBound(nodes,2)+1)
nodes(0,UBound(nodes,2)) = CLng(sAr(0))
nodes(1,UBound(nodes,2)) = CLng(sAr(1))
SKIPLINE:
Wend
Close #1
'*** 2) CREATE ELEMS
el.type = FET_L_BEAM : el.topology = FTO_LINE2
el.propID = 'FILL IN!! specify propID - could also select it with a prop object...
el.orientID = 'FILL IN!! trick: orient with node or vector...? 0 if vector, nodeID otherwise
Dim v1 As Variant, v2 As Variant 'if orienting with vector
For i = 0 To UBound(nodes,2)
el.Node(0) = nodes(0,i) : el.Node(1) = nodes(1,i)
'if orienting with vector:
App.feCoordOnNode(nodes(0,i),v1)
App.feCoordOnNode(nodes(1,i),v2)
For j = 0 To 2
v1(j) = v2(j)-v1(j) 'vector n1=>n2
Next
'orthogonal vector, should work for orient
If v1(0)<>0 Or v1(1)<> 0 Then
v2(0) = -v1(1) : v2(1) = v1(0) : v2(2) = 0
Else
v2(0) = 1 : v2(1) = 0 : v2(2) = 0
End If
el.orient(0) = v2(0) : el.orient(1) = v2(1) : el.orient(2) = v2(2)
'end part "if orienting with vector"
el.Put(el.NextEmptyID)
Next
End Sub
and you can choose between Rigid, Line elements (beam, spring damper...). A dialog box asking for the orientation vector will appear after hitting OK.
And you are done.
SN
2) often they're not the closest nodes.
2) I don't know exactly how the nodes are sorted in your model. But it works fine for closest nodes...
Here is a gift for you...and for Femap community.
Just enter your elements IDs in one column (there is a button to get the Max Elem ID). Existing Property ID and Node 1 IDs Nodes 2 IDs and your are done.
Then go to Femap to define the orientation vector. I don't have enough time to put it in the Macro...
Like this you would control the creation of these elements.
SN
Here is the macro without Password. Under VBA go to tools / references,
uncheck the Femap version already defined and upload the femap.tlb which is in the current Femap version directory and hit Ok.
Retry and keep me informed.
SN
Seif Eddine Naffoussi, Stress Engineer
www.Innovamech.com
33650 Martillac – France
