ANNEX 3-F Design Fatigue Curves
Gents,
I have one question about the annex 3-F.
What fatigue curve I need to use for the calculation of a high pressure sphere that have a weld joint in the middle of the hemisphere head? 3-F.1 or 3-F.2?
Also when I can use the both cases? I understand that the curve should be used to calculation of supports. That is correct or not?
Kind Regards,
GFJ
RE: ANNEX 3-F Design Fatigue Curves
What's the UTS of the material. Shouldn't you be using the Structural Stress Method for a welded joint?
