How to un-section a drawing view
I have made a section view of a shaft in my drawing and now I want to have this view go back to the original
un-sectioned view.
How do I do this?
Thank you,
Jeff
RE: How to un-section a drawing view
I don't think there is a way to do it other than deleting it and creating a new projected view (assuming that it is a projected view).
Han primo incensus
DanStro is correct. A section view is derived from its parent view. You will need to delete the section view and replace as DanStro mentioned.
Chris, CSWA
SolidWorks 14
ctopher's home
SolidWorks Legion
Were you asking about a section view (which is a complete view unto itself) or a broken out section (which shows a section of a selected area of an existing view)? If it is a standard section view then as they said you have to delete the entire view and start over. If however it is a broken out section, it will appear in the FeatureManager Design Tree as an item under that view. You can select and delete just the broken out section in the Feature Manager.
I was talking a section view not broken view for I have been able to un-do a broken view.
That's a real bummer on not being able to un-do a section view and having to delete and insert a new projection view.
In Pro-Engineer you create a section view and if you want to un-do it so you go back to the original model you double click on the section view and a window opens and you click on section and then click NO SECTION and the section view is gone and you have the original model left.
Soildworks needs to fix this.
Thank you for your input.
Jeff
Move the section (cutting) line so that it doesn't cut the parent model.
That's an interesting work-around. Then you can hide the section line.
Han primo incensus
... or just move it outside the border.
My assumption is the dimensions in the former section view will "brown out" because the edges have "changed." Give it a try though... I am curious.
-Dustin
Professional Engineer
Pretty good with SolidWorks
I just sent in an enhancement request for this functionality.
ER# 1-6123654766
Everyone go vote for it!
David
Check out my professional profile and connect with me on LinkedIn. http://lnkd.in/fY7-QK
No one can vote for an ER #. Only the contributor & SW personnel can view those.
Others can only add votes once an SPR number has been issued.
You guys are right...
I'll post the SPR if it gets that far.
David
