Non linear reinforced geopolymer concrete beam
Hi Everyone,
I am posting in the hope that someone may have some sort of useful resource or might know this yourself, as the time frame I have to do this is very tight. :(
I'm completely new to using ABAQUS and I am setting out to create a reinforced geopolymer concrete beam - hoping to attain load-deflection curve, cracking pattern and flexural capacity. My variables are longitudinal reinforcement ratio and concrete compressive strength. At this point I am aware I will need to somehow create a stress-strain curve in the program in order to represent the concrete as specifically geopolymer concrete.
As time is such an issue at this point - if anyone could provide maybe some sort of link or tutorial or file of some sort that could provides a similar solution that would be extremely appreciated.
Thank you!
