NX9 Hidden sketch constraints bug?
Hi there. I noticed a strange behaviour when i use the technique of hiding an object and then inverting the visibility: Ctrl+B, then Ctrl+Shift+B. The anomally is that sketch constraints dissapear in all the previous sketches, both for sketch edit and sketch task environment. Has anyone else noticed this fault?. The version i use is 9.0.2.5. Bye.
RE: NX9 Hidden sketch constraints bug?
Behaviour is the same in NX8.5.
If you use Ctrl+Shift+B to Invert the Hidden/Shown then do it again, the constraints disappear and appear.
It's only if you blank all, that you don't get them back and in a quick test I couldn't find a way to get them to appear again.
Report it to GTAC if you've got an issue with it.
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.2, NX10 Beta
Checked in GTAC, it is a bug and reported as fixed in NX10.
Anthony Galante
Thanks for the info Mr.Galante. I'm glad it's solved for future versions.
