Staad Pro calculation applying with EN 1993-1-8:2005 chapter 3.10.3
Hi
I am working together with a steel designer who is using Staad Pro. The design is to comply with EN 1993 however only EN 1993-1-1 can be selected in Staad.
Does this consider what is written in EN 1993-1-8, more specifically what is written in chapter 3.10.3 regarding the ultimate resistance?
According to this chapter the design resistance is affected by a reeducation factor which depends on the design of the bolted connection.
If this isent included how is it implementet in to STAAD?
Thanks in advance I would rely appreciate if someone could help me understand this part.
RE: Staad Pro calculation applying with EN 1993-1-8:2005 chapter 3.10.3
The requirements of BS EN 1993-1-8:2005, as noted below, are not implemented in Staad.Pro.
<see image 1>
However, a design check is implemented which allows for holes due to fasteners in accordance with BS EN 1993-1-1:2005:
<see image 2>
This is allowed for by using the Design parameter noted below:
<see image 3>
