compressed air drip leg
Hi
I just wonder if it is necessary to design drip leg for water residues before air preparation block (filter/regulator w manual drain + lubricator).
Compressor is equipped with a refigerant air dryer. All piplines are in heated rooms.
Chris
Chris
RE: compressed air drip leg
No drip leg.
The dryer will work most of the time. The drip leg is useful for upset conditions in the dryer and for removing sediment or other contamination.
Its cheap and effective...
http://www.omega.com/auto/pdf/CompressedAirTips.pd...
MJCronin
Sr. Process Engineer
you must get smarter than the software you're using.
