Searching for Heat Detector, Help!
I'm a field engineer with a current situation where the barge[for pipeline installation] is set near the flare system. I'm currently searching for the best heat detector that fits the specifications below:
[EASY INSTALLATION, TEMPERATURE SET ALARM, ADJUSTABLE, MOUNTED-ON POLE, BACK-UP BATTERY, PRODUCE HEAT MAP]
I've looked everyone and I could find any,
Could someone help me?
