API RP 14E
API RP 14E
API RP 14E
DEAR ENGINEERS,
I NEED ASSISTANCE IN ESTIMATING THE VAPOUR PRESSURE OF CRUDE IN MY NPSH(AVAILABLE) CALCULATIONS.
RE: API RP 14E
Can vary hugely depending on what processing has taken place upstream. Your boiling point could be anything from sub zero C to over 100C. How are we going to know??
This needs specific info from your client / operator / process engineer.
RE: API RP 14E
Your supplier should know but try 10 psi, 12 if you think the crude may be very light
RE: API RP 14E
But at what temperature? This is very often critical in Hydrocarbon fluids. VP/NPSH could be OK at 15C, not OK at 30C
