Macro to check for duplicate dimensions
Hi
I am new to this forum, and some help on a problem would be great.
I was thinking of creating a macro to check for duplicate dimensions across different views in a drawing file.
I have never used VB scripting before. But, I have written the equivalent code in C++ (which i am familiar with)
Now, I want to read dimensions from a drawing file, and put it in a file from where i can use the following algorithm.
I think it is possible, i just don't know how. The C++ algorithm is below:
#include<iostream>
#include<conio.h>
#include<stdio.h>
void clear_screen()
int i;
for(i=0;i<100;i++)
std::cout<<"\n";
using namespace std;
int main()
clear_screen();
int no_views, dim_max;
float dims[10][100];
int counter,ctr, ctr1;
std::cout<<"Enter total no. of views in drawing sheets\n";
std::cin>>no_views;
std::cout<<" out of all the views, please enter the number of dimensions in the view with the most dimensions\n";
std::cin>>dim_max;
std::cout<<"start entering dims. view wise\n";
for(ctr=0;ctr<no_views;ctr++)
{ ctr1=ctr+1;
std::cout<<"enter dimesnsion for view: "<<ctr1<<"\n";
for(counter=0;counter<dim_max;counter++)
std::cin>>dims[ctr][counter];
//output check
std::cout<<dims[0][3]<<"\n\n";
std::cout<<"entered dims as follows\n";
std::cout<<dims[ctr][counter]<<"\t";
std::cout<<"\n";
if(no_views<=1)
std::cout<<"No comparison needed\n";
else
/* Somehow, we have to get inputs of the dimensions from all views in VBA and store in array dims */
int i,j,k,dj;
j=no_views-1; dj;
int dim;
do
dj=0;
do
/*cout<<"view no "<<(dj+1)<<"\nenter total no of dimensions in current view:\n";
cin>>dim_max;
for(k=j-1;k>=0;k--)
for(dim=0;dim<=dim_max;dim++)
if( (dims[j][dj]==dims[k][dim])&&(dims[j][dj]!=0))
std::cout<<"following dimension repeated, check!: "<< dims[k][dim]<<" view number: "<<(j+1)<<"\n";
else
std::cout<<"not repeated yet\n";
} //end of inner for loop
} //end of outer for loop
dj++;
} while (dj<dim_max);
j--;
}while(j>0);
getch();
return 0;
Any ideas?
#include<iostream>
#include<conio.h>
#include<stdio.h>
void clear_screen()
int i;
for(i=0;i<100;i++)
std::cout<<"\n";
int main()
clear_screen();
std::cin>>no_views;
std::cin>>dim_max;
{ ctr1=ctr+1;
//output check
std::cout<<"\n";
if(no_views<=1)
else
int i,j,k,dj;
j=no_views-1; dj;
int dim;
do
dj=0;
do
cin>>dim_max;
for(k=j-1;k>=0;k--)
else
dj++;
j--;
}while(j>0);
getch();
return 0;
Any ideas?
RE: Macro to check for duplicate dimensions
Well, in my opinion this is a little bit tricky...speaking from engineering point of view this is possible...you can have same dimension in different views for different objects.
Otherwise, if you are interested just to find dimensions values...this is a quick modification of another macro which I'm sure is existing here in the forum but I wasn't able to find it.
CODE --> CATScript
' ====================================================== ' Purpose: Macro will write all dimensions in an active CATIA drawing to a text file ' Usage: 1 - A CATDrawing must be active and dimensions should also exist inside ' 2 - Run macro ' 3 - Use a rectangle selection to select all your dimensions ' Author: ferdo (Disclaimer: You use this code at your own risk) ' ====================================================== Language="VBSCRIPT" Sub CATMain() Dim InputObjectType(0) As String set document = CATIA.ActiveDocument If TypeName(document)="DrawingDocument" then set oSelection = document.Selection InputObjectType(0)="DrawingDimension" oSelection.SelectElement3 InputObjectType,"Select points", _ true,CATMultiSelTriggWhenSelPerf,false WriteTxTFile(oSelection) oSelection.clear Else End If End Sub Sub WriteTxTFile(oSelection) Dim sPath As String Dim sTime As String Dim sName As String Dim sFile As String documentname = CATIA.ActiveDocument.Name position = InStr(documentname,".CATDrawing") position = position -1 documentname = Left(documentname,position) sPath = CATIA.Application.SystemService.Environ("CATReport") sName = "\DrawingDimension_" & documentname & ".TXT" sFile = sPath & sName Set oFileOut = CATIA.FileSystem.CreateFile(sFile,TRUE) Dim oStream As TextStream Set oStream = oFileOut.OpenAsTextStream("ForWriting") For i=1 to oSelection.count Set Dimension = oSelection.Item(i).Value oStream.Write Dimension.GetValue.Value & vbCrLf Next oStream.close MsgBox "Check the file : " & sFile, vbInformation ' information about job done End SubRegards
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
Yeah, I knew that there are cases where the same value of dimension is used for different features on a drawing. But, I still want to do this, because sometimes when there are a lot of dimensions, just a highlight of the dimension repeated can guide the draftsman. We can then use our logic to check if it is really duplicate or not. we don't have to pore through everything.
Anyway, your macro for getting dimensions in a text file was flawless!! Thanks for that! I can save it as an excel file also, which is interesting. If I can somehow segregate dimensions from different views into an excel sheet, i can maybe insert my algorithm there. Is that possible with a catia macro? asking user to just pick rectangles enclosing single views at a time, and saving those dimensions in the same excel sheet?
Thanks for all the help!
Gaurav
Of course you can do much more in a CATIA macro...you can go thru each sheet (if you have more) and thru each view, get all dimensions...you don't need to select something (like in this macro), just use search criteria in a loop for each view and each sheet, save all in Excel or whatever.
You can search forum for more examples.
Fernando
