flushing ring gasket
hello, can anyone explain what is the torque value to use if i have two type of gasket one on each side of a flushing ring. one gasket is spiral wound and the other is graphoil as default gasket provided by rosemount level transmitter diaphram seal. Is this a common practice to have one type of gasket on each side of a flushing ring.
thanks,
thanks,
RE: flushing ring gasket
