Threaded SMC fittings
Hi friends, I make design of new part for hot pressing from SMC prepreg. And I need to add two usual fittings with external thread 1" and 1/2" as elements of the part. But my moldmaker says that it is impossible to make threads from SMC well as it's impossible to cut threads on ready parts! I absolutely do not want to use special small metal inserts for bolts and use flanges but not standard inch fittings! Could you please recommend how to make thread from SMC composite?
Hope for your kind help!
RE: Threaded SMC fittings
We need usual fittings 1" and 1/2" for standard nuts on our part, max pressure is 10 bar, but temperature cycles until 120-150C are possible - that's why I do not want any inserts, but only original SMC body.
