Error Solidworks simulation
I am running some tests on bearing deformation due to known load on a specific roller (I do not know the load of the whole system with all rollers included). I know there is a load of 600 kN on the lowest bearing, but when I run the system using no penetration contact for the global components and using a fixture on the outer ring, the error "Model is unstable, make sure you have applied adequate fixtures to stabilize the mode".
Here are pictures of what I have and what I want to do.
http://files.engineering.com/getfile.aspx?folder=9...
http://files.engineering.com/getfile.aspx?folder=6...
Help would be much appreciated, if any questions would help solve the problem, please don't hesitate to ask.
thanks in advance,
Paco
thanks in advance,
Paco
