FEMAP API Using feOutputCalculate
I am new to working with the FEMAP API and am trying to calculate some vectors using the API. I have used the Model->Output->Calculate feature to calculate these in the past, but the models I am working on are very large, and I want to be able to run the API at night while I go home and the computer cranks away. Here is the code I am using:
Sub Main
Dim App As femap.model
Set App = GetObject(,"femap.model")
Dim s As femap.Set
Dim v As femap.Set
Dim e As femap.Set
Set e = App.feSet
Dim ov As femap.Output
Set ov = App.feOutput
Dim mx As Double
Set mx =App.feOutput
Dim my As Double
Set my = App.feOutput
'Select Output Set and Output Vectors of interest
If App.feSelectOutput("Select Output Vectors",0,FOT_ANY,FOC_ANY,FT_ELEM,False,s,v) = FE_OK Then
If e.Select(FT_ELEM,True, "Select Elements" ) = FE_OK Then
While s.Next()
v.Reset()
While v.Next()
'Calculate Mx'
mx.feOutputCalculate(s.CurrentID(),8,e.CurrentID(),"Mx'","i","Case","(Abs(Vec(!Case;9000003;!i))+Abs(vec(!Case;9000005;!i)))*Abs(vec(!Case;9000003;!i))/vec(!Case;9000003;!i)")
'Calculate My'
my.feOutputCalculate(s,8,e,"My'","i","case","(Abs(Vec(!Case;9000004;!i))+Abs(vec(!Case;9000005;!i)))*Abs(vec(!Case;9000004;!i))/vec(!Case;9000004;!i)")
Wend
Wend
End If
End If
End Sub
The errors I get are on the lines with the feOutputCalculate and are both Invalid Instruction.
Any ideas would be greatly appreciated.
Sub Main
Dim s As femap.Set
Dim v As femap.Set
Dim e As femap.Set
Set e = App.feSet
Dim mx As Double
Dim my As Double
While s.Next()
v.Reset()
While v.Next()
'Calculate Mx'
'Calculate My'
Wend
Wend
End If
End If
End Sub
RE: FEMAP API Using feOutputCalculate
Here's a shot at a cleaner version of your code (bottom).
One point needs to be explained: from your code I assumed you use static vector IDs (9000003 4 and 5), meaning for all output sets you have created equivalent output vectors with the same IDs before running this. If this is not the case then my code won't do.
AP
Sub Main
Set App = feFemap()
Dim s As femap.Set, e As femap.Set
Set s = App.feSet
Set e = App.feSet
If s.SelectMultiID(FT_OUT_CASE,1,"Select OutputSets") = FE_CANCEL Then End
If e.Select(FT_ELEM,True, "Select Elements" ) = FE_CANCEL Then End
While s.Next()
'Calculate Mx'
App.feOutputCalculate(s.CurrentID,FT_ELEM,e.ID,"Mx'","i","Case", _
'Calculate My'
App.feOutputCalculate(s.CurrentID,FT_ELEM,e.ID,"My'","i","Case", _
Wend
End Sub
