REVOLVED VIEW MANAGEMENT in NX8
I dcan't get the revolving section view in Drafting.........
Maybe because is Friday...........( bigsmile )
Could somebody help me in this matter?
The Documentation Help Menu doesn't provide specifical information regarding this specifical subject.....
MZ7DYJ
RE: REVOLVED VIEW MANAGEMENT in NX8
OK, thanks you!
MZ7DYJ
For a better understanding.....What is the difference between a simple Section View and a Revolved one?
MZ7DYJ
First off, while it's possible to create the equivalent of 'Simple Section' view using a 'Revolved Section' view where the sections are aligned, it's impossible to create a true 'Revolved' section using a 'Simple Section'.
Basically a 'Simple Section' is single straight cut through the model, while a 'Revolved Section' view has at least two cutting-segments, which share a common pivot point, which when created shows the 'cuts' displayed in 'true-length' view segemets developed into a single 2D view. If you look at the 'Section Lines' and the arrow directions, it should pretty obvious what it is that the final view is showing you.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
What exactly are you asking? If you're attempting to model what's happening when you made that Section view in your Drawing (BTW, WHY are you NOT working Master Model mode?), fine. And if so, then the 'Extrude' is what's happening.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
OK, I think that I understand now……
I was misled by the name (Revolve, which involve rotation) of the Revolve Section tool.
I thought that this kind of section is created based on a theoretical rotation cut.
MZ7DYJ
No, if means that the 'segments' are revolved about common points relative to each other.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks!
MZ7DYJ
John Baker's reply:
(BTW, WHY are you NOT working Master Model mode?)................
What do you mean by that, having the 3D model attached as a component for the 2D file?
If this is the case, In this thread I tried to focus on the topic, ignoring the other details…..
MZ7DYJ
That's OK. In fact, after I responded I sort of got that notion myself, but since you can't go back and edit these posts, I was stuck with what I had written. Sorry.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
That's OK, no problem.
MZ7DYJ
