Import DXF - is it basically a bad idea?
Typically, text moves, lines vanish and so on when importing a DXF.
Now sitting where I do, people send me their DXFs and I'm wondering if really, importing DXFs is basically a bad idea.
I've got my own thoughts on this, but would be interested to here anyone elses opinions?
www.jcb.com
NX 8.5 with TC 8.3
RE: Import DXF - is it basically a bad idea?
www.nxjournaling.com
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
Bit of background - we're talking here about drawings that suppliers have sent in to us.
The example I've got at the moment:
- open the DXF in Vis and some of the dimension values and leader annotations are missing
- import to NX and some of the text moves
- import / open / translator to NX (as suggested) and a table is missing
And the title block is missing in all imports.
So in effect the engineer doesn't know what it's supposed to look like, and has asked me why it won't import properly.
When I was in engineering I would ask the supplier for a different format (CGM, or PDF to attach in TC), because at least I'd know it was correct. I wouldn't clean it up because it's a proprietary drawing, and I didn't know what it was supposed to look like.
But in the job I'm in now I often get asked why they won't import properly. I don't really have a satisfactory answer to this which is why the question - is it a bad idea. I was wondering if anyone else had experienced similar.
Thanks again for your answers, I can tell the engineer what I've tried and suggest he gets a different format!
www.jcb.com
NX 8.5 with TC 8.3
The internal import moved / changed text on the drawing.
The external import and simply open options gave similar results, a better job of the text but things were still missing on the drawings.
It all seems too "flaky" for me, as it's an engineering drawing to my mind it should either open properly, or not be used as an export / import option.
www.jcb.com
NX 8.5 with TC 8.3
There's a good chance they were different as I did the internal import last Friday, other imports this morning.
So in your experience import method doesn't really matter, only the settings used and the file.
Which means there isn't really a "bulletproof" method for importing DXFs?
www.jcb.com
NX 8.5 with TC 8.3
http://en.wikipedia.org/wiki/AutoCAD_DXF
www.jcb.com
NX 8.5 with TC 8.3
"shit in, shit out" you know. E.g. we had a dxf file that would not import properly because the file contains two "supermarket layouts" that were kilometers apart and both were in one file. Every layout in one file was easy to import. If you have "access" to the import AND export you can control both. If you have only "access" to one of them it can (and often will) fail. So often it is not only a problem for NX but also from the exporting software...
The NX tools do provide the possibility of importing some DXFs, if the engineer is willing to play with the settings, and has something they can check the results against.
In any case I have the answers I need now, which are that I can't recommend it because of possible errors, and it's not something that can be fixed.
Thanks for your time.
www.jcb.com
NX 8.5 with TC 8.3
Cj Silver
Tooling Engineer BAE Systems
Working to remember all I forgotten
Every vendor will have their dialect on these files, except Autodesk.
I use Autodesks viewer TrueView ( freeware) to verify the content , before and after. ( If i export from NX i check the results there, if i am about to import i check the file before import.
One of the problems with these formats is that very many Autodesk users , think that DXF/DWG is the format and are very reluctant to use Step.
I think that "today" the external and the internal translator is the same and produces the same result. I thinkthat it was not some years ago.
( Correct me if i'm wrong, but , say 2004, we got different results internal/ external translator.)
This week i had issues with an DWG import into NX7.5
compared to the DWG TrueView the result was quite different.
I imported the DWG into NX903 where it was identical to the DWGTrueView.
I exported it NX9 -> DWG and imported the new DWG into NX7.5 , case closed.
Tomas
