How are these o-rings made and what is the cause of failure?
Click here for image album
This is a 26mm o-ring which failed after not much use. It was being exposed to 200 Bar every 30 seconds, 8 hours a day for a few days before failing.
I have two questions.
1. How is this sort of o-ring made? It looks like it has been rolled from a flat sheet but I cannot see a join. The last roll edge seal runs around the whole o-ring.
2. How did this fail? Is this a manufacturing problem or incorrect fitment?
RE: How are these o-rings made and what is the cause of failure?
Thanks guys.
