Heat treating o-rings to raise durometer
I have a high pressure system with an o-ring and backup o-ring that is jamming. The suspect is the pressure extruding the backup o-ring into the gap between the rod and cylinder.
The backup o-ring is rated at 90A. I was wondering if I could heat treat the O-rings and permanently increase the hardness. If so any ideas as to the heating profile?
RE: Heat treating o-rings to raise durometer
http://www.darcoid.com/images/uploads/pdfs/Parbak-...
This is what happens in high temp service.
Use a proper backing ring, and maybe you need a different elastomer for your service.
Just because a ring is Viton does not make it the same as other Viton. The fillers and additives are critical.
Plymouth Tube
If you currently have an o-ring and 1 backup washer, your gland might be properly sized for a u-cup, you'd have to check the book. Parker claims O-rings can be effective up to 5000 psi, but for all practical purposes, I've found that to be a bit optimistic, particularly in high heat applications. >140 is fairly hot for a hydraulic system.
