3A standard vs BPE Standard Pipe fittings
Our Project team wants to change ASME 3A standard sanitary fittings vs. BPE sanitary fittings. I was not able to find exact difference between these fittings. Can any one explain differences and impact??
RE: 3A standard vs BPE Standard Pipe fittings
http://www.hollandapt.com/static.asp?path=2966
you must get smarter than the software you're using.
