GM KBTD Hole chart and manual boundaries
Using manual boundaries for a drafting view (for clarity). When we run the GM KBTD hole chart program and "update chart and symbols" it will put in ALL symbols as if it had an automatic boundary. I.E. there are hole symbols outside the view area, even outside the drafting sheet.
Is there any way to override the update to only show the hole symbols inside a manual- or break-line/detail-boundaried view?
