Copying Title Block contents?
Is there any method to copy contents of title block from one drawing and to paste it another drawing?
I would like to copy the title block contents which mostly reoccurs like material spec, heat treatment, protective treatments, name, etc., from 'old drawings' and to paste in the new drawing, like copying & pasting cells in excel.
Using 'Macros' is good idea, but i dont have macros for the old drawings.
RE: Copying Title Block contents?
If it is simply text then you can just copy and paste it into the new drawing.
Its not a simple text.. Its comes with the company's drawing template as titleblock.. I fill it using 'populate titleblock' option.
