NX expression
NX expression
NX expression
Hi everybody,
I am trying to find NX expression for this situation:
If parametr_62=0 and parametr_65=0 then return 0, else return 1.
IF(p62=0)(0)else(1) ... works
IF(0=p65)(0)else(1) ... works
IF(p62=p65=0)(0)else(1) ... doesnt works (but is excepted)
Do you have any experince with this ???
Could you help me ?
Thanx
Jara
RE: NX expression
try instead:
IF(p62=0 AND p65=0)(0)else(1)
kukelyk
RE: NX expression
I have tried something like this:
IF(p7=200)(IF(p8=200)(200)else(100))else(100)
This means, that:
when p7 dimension is 200, next IF statemnet is checked. Next statement says, that if p8 dimension is also 200, the third dimension will also be 200. If this second dimension (p8) is not 200, the third dimension is going to be 100.
when p7 dimension is anything else but 200, next IF statement is not relevant. The third dimension is automatically 100.
Hope that this will help.
RE: NX expression
Instead of AND in kukelyk example, write down &. So, that expression would like like this:
IF(p62=0 & p65=0)(0)else(1)
Then it will work as you would like.
RE: NX expression
Hi again,
thank you for the answers!
2Kukelyk: AND doesn´t work
2SvenBom: yy, that is OK!
IF(p62>0)(1)ELSE(IF(p65>0)(1)ELSE(0))
and funny is this:
IF(p62+P65=0)(0)else(1)
Take care
Jara
RE: NX expression
What's so funny about 'IF(p62+P65=0)(0)else(1)'? It's actually pretty elegant to say nothing of being very creative.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: NX expression
Exactly !!!
I have totally omitted so simple solution smile
Jara
