WPQR test for EN 12952 boiler construction
Is their any way we can avoid impact tests while qualifying welding procedures for EN 12952 steam boiler construction, in view of high temperature of the application? Reference standard EN 15614,Specification and qualification of welding procedures for metallic materials- Welding procedure test, specifies impact test. The test temperature is to be decided as per the application but for high temperature boiler application impact test does not seem to be relevant.
RE: WPQR test for EN 12952 boiler construction
Consiedering your application, high temperature boiler, impact testing is a cheap CYA should a failure occur.
Risk vs. reward.
