Tilt on right rear side of SUV
I have a suv which has a tilt towards right rear side. Tilt is there even no one is sitting in the suv and suv is on a flat surface with equal tire pressure. Can some one please help if it has some thing to do with vehicle going outside the lane on straight road with minimum crown? Which side suv should go with right rear tilt.
I would appreciate it.
RE: Tilt on right rear side of SUV
It should go to the shop to get that broken spring replaced.
Mike Halloran
Pembroke Pines, FL, USA
Measure from the ground to the centre of the wheel, and from the ground to the lip of the fender above each wheel centre, for each wheel.
Get back to use with the measurements. If teh ground isn't level you are wasting your time on this BTW.
Cheers
Greg Locock
Hi, Which SUV vehicle is this ? Can I guess Landcruiser ?
