select all on a certain layer?
3
Is there a simple way to select all the items on a certain layer, without turning off all the other layers and doing a box around what's left?
RE: select all on a certain layer?
Not that I know of, but you can speed up the process if you use the following commands to turn off and on the layers.
ISOLATELAYER
UNISOLATELAYER
cheers! that's super helpful!
