Pattern features on a spiral surface
New SW 2014 user
Checked the archive, did not see an answer to my problem...
I created a sketch of a 2D spiral curve, then Extrude Surface. This creates a spiral surface.
Next, I created another 2D sketch, lines and curves, tangent to the spiral surface.
Then using Wrap, I can place the sketch on the surface, creating lines and curves that match the surface contour.
Then I can do Linear Pattern to pattern my feature down the axial direction of the surface.
However, what I want to do next, is to pattern my feature along the spiral direction of the surface, either out (increasing radius) or in (decreasing radius).
I tried both Sketch Driven Pattern and Curve Driven Pattern, trying to get the sketch to pattern along the surface, but no luck.
Suggestions?
Suggestions?
RE: Pattern features on a spiral surface
See attached...
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum Policieswww.SuperATV.com
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
