cannot edit assembly elemets
I have this problem and it is driving me nuts. I can create, for example, a hole in an assembly, but once it is created i just can not edit it. The edit icon is gray.
Could somebody help me with this?
Thank You in advance.
RE: cannot edit assembly elemets
Example:
1. open assembly
2. select Hole command
3. select Create Assembly-Driven Part Feature
4. place holes on the parts in the assembly.
Now, if you open any of the parts from this assembly, you will see the holes. But they are created at the assembly level, therefore you can not edit those in the part. If you want to change those holes, you have to open assembly and check the Assembly-Driven part features in the Assembly Pathfinder. There, you will see your hole and you will be able to edit it.
If you have a different problem, can you attach an image (which edit icon is gray, etc.) or a movie showing the problem?
Ken G.
http://grundey.blogspot.com
Have you checked out the Solid Edge Community site?
http://community.plm.automation.siemens.com/t5/Sol...
