Section dimensions of 760UB220
I am trying to find information on the dimensions, including web thickness and flange thickness, for a 760UB220 (used in a bridge built around 1989). According to the drawing, the size is from AS 1131. Does anyone has this information to share?
RE: Section dimensions of 760UB220
Thank you hokie66. I need to know the dimensions so that I can load rate the structure. I have to check whether the section is compact or not.
