Corrosion resistance 4140 ammonium nitrate
Hi all,
Can anyone steer me in the direction of where to find corrosion resistance data for 4140 steel against ammonia nitrate attack.
A table, chart or book would be great.
Thanks in advance
Thanks in advance
RE: Corrosion resistance 4140 ammonium nitrate
http://www.eng-tips.com/threadminder.cfm?pid=1529
Use translation assistance for Engineers forum
Note the rules include No Student posting
The support steelwork if failing because its not strong enough and someone suggested 4140 for the strength.
Its for an underground vehicle.
At least for straight AN.
How much corrosion protection you will get from the fuel oil is something for you to decide.
Plymouth Tube
Are there any other corrosiontables containing that contain a high strength high corrosion resistance steel for AN?
http://www.smt.sandvik.com/en-us/materials-center/...
http://tools.outokumpu.com/spt/corrosion/search_he...
They are high strength (not quite as high as Q&T 4130) but much stronger than other CRAs.
Alloys such as LDX2101 and ATI2102 are a good place to start.
Plymouth Tube
