Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...your web site's great! I've been using this system for almost a year now and find it really, really helpful. The people have been helpful in answering just about any question you post in the forums..."
Geography
tbs (Civil/Environmental)
1 Dec 00 16:15
I recently aquired a couple of 3 phase Yale Chain Hoists. They are wired for 440. I only have 220. When I opened them to switch wiring....there were no extras. 3 wires come directly from the windings. I have a diagram from the company but haven't a clue what to do next.
jbartos (Electrical)
2 Dec 00 19:01
Please, is your 220V single- or three-phase?
HUNJAN (Electrical)
5 Dec 00 12:50
TBS------IF THE MOTORS ARE RATED AT 440V WITH ONLY 3 LEADS FOR SUPPLY THEN IT MAY BE RUN ON 220V SUPPLY,BUT THE INTERNAL CONNECTIONS WILL HAVE TO BE CHANGED ie THE MOTORS YOU HAVE ORIGINALY MAY HAVE "STAR"CONNECTIONS IN THE WINDINGS. SO TO RUN ON 220V 3PHASE THE MOTORS WILL HAVE TO BE RE-CONNECTED TO "DELTA" CONNECTIONS. I HOPE THIS ADVICE WILL HELP YOU. GOOD-LUCK.
5 Dec 00 16:50
Suggestion: It appears that 440/sqrt3=254V not 220V. Some 3-phase motors have on their windings a mid tap that enables the parallel connections of windings; therefore, the operation at 220V is possible, i.e. one half or 440V.
Guest (Visitor)
21 Dec 00 14:35
just use a 3 phase distribution transformer-wire it in
reverse..480 to 208/120-use the 208 side as your 3ph input and wire the chain hoists to the 440V side of the transformer..
Guest (Visitor)
15 Feb 01 11:59
I have a small AC electric motor which I am trying to use for another application. The motor has four connections with white, green, black and red wires attached. Someone else in the history of this motor combined the white/green and the red/black in order to use a two prong plug. The power cord is shot and I am trying to replace it, but am unsure of how to connect the four wires into three. Any suggestions?
15 Feb 01 17:16
Suggestion: Copy the motor nameplate data and post them in here.
Close Box
Join Eng-Tips® Today!
Join Us             Close
